10-14-2009 04:21 AM - edited 03-06-2019 08:07 AM
We are looking to move our power from 110 to 220. We have 2 power supplies running in a non-redundant configuration. Is this ok to move one supply at a time to 220 without causing problems?
Solved! Go to Solution.
10-14-2009 09:34 AM
Check the power supply box. If it says 110-220, then you are fine.
10-14-2009 09:34 AM
10-14-2009 09:50 AM
Great, thank you very much. I had thought this would be fine but I wanted to 100% sure.
Thanks again,
Mike
10-14-2009 10:06 AM
Anytime. Please mark this thread resolved if it is.
10-14-2009 01:08 PM
You may want to check the following document for further and future reference as it contains what happens when you swap/add power supplies of equal/unequal wattage.
Table A-43 Effects of Power Supply Configuration Changes
10-14-2009 03:45 PM
Thank you very much. This is actually the document I was looking at, and although it did say power supplies of unequal output, it did not say anything about different inputs. But after reading another document which explained that the power supplies are completely isolated, i come to the determination that the input did not matter because it is converted into the output, which is what matters. I hope I am not off the mark here. Thanks again
