%Reload in Progress
Oct 14th, 2009
I have a Catalyst 4500 WS-C4506 and
WS-X4516-10GE Supervisor running under
IOS 12.2(52)SG IP BASE SSH. After having
installed IOS 12,2(53)SG i wanted to schedule a reload. After entering the reload at command I get the message %Reload in Progress and nothing happens.
Any ideas thanks
Giuseppe Larosa Wed, 10/14/2009 - 10:53
hello Manfred,
if you use reload at it expects a time
reload at ?
hh:mm Time to reload (hh:mm)
if you want to reload immediately just type
Hope to help
MANFRED LIEBCHEN Thu, 10/29/2009 - 07:19
Hello Guiseppe,
i used the full reload command, i.e.
reload at 04:00 14 Oct IOS-Upgrade
but the reload is not scheduled instead I get the error message %Reload in Progress
iyde Thu, 10/29/2009 - 09:16
Hi Manfred.
What does the output of show reload look like?
Could you try a reload cancel before you then try to do the reload?
It might be a bug in the IOS - have you checked the bug toolkit?
HTH, Ingolf
craig.juhas Tue, 07/10/2012 - 07:03
Hi Manfred, did you get to the bottom of this '%reload in progress' issue?  I'm experiencing the same problem and it appears it's related to the aaa config as the problem doesn't occur if I remove the aaa config before attempting the reload.
