temporarily disable rules?
Answered Question
Oct 14th, 2009
What's the best way you have found to temporarily disable certain rules in an ASA config (8.2.1). AFAIK there is no way to comment out a line in an ACL....So if we have a SQL connection that we need to open up from time to time (but are not comfortable leaving open permanently) whats the best way to do this?
Correct Answer by jeromecandiff about 7 years 6 months ago
In 8.x you have the ability to disable certain aces.
Overall Rating: 2 (1 ratings)
Jon Marshall Wed, 10/14/2009 - 07:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
2 ways that i have used
1) have a copy of the acl with a different name in the config and without the SQL line and then simply apply whichever acl you want to use at the time to the relevant interface
2) You can specify line numbers in acls so you can do
no access-list line SQL rule
and then when you want to allow it simply add it back in
Jon
slug420 Wed, 10/14/2009 - 07:33
Actually you just gave me another idea....
Maybe I will put it in the ACL as line 10 or something and then put the same rule with a deny action as line 9. When I want to use it I remove the deny, and when I am done I re-add the deny (which is simple since im just copying the existing line and changing permit to deny)
Jon Marshall Wed, 10/14/2009 - 07:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
Yes that would work as well, just make sure you get the line numbers correct or you could allow when you mean to deny and vice-versa.
Jon
Correct Answer
jeromecandiff Wed, 10/14/2009 - 09:14
