AMD / CPA on ICM 6 just doesn't work, HELP!!
voiceops
We're running IPCCE 6 (with IP IVR QMANAGER) with Outbound Option configured with 10 ports. Our calls go out via PRIs.
We have several IVR outbound campaigns (Transfer to IVR Campaign = checked
Enable IP AMD = checked
Transfer to IVR Route Point = checked
Terminate Tone detect = checked
TDM Fast Voice Detect = checked )
and our dialer just doesn't know when is an answering machine picking up.
I've tested it by calling into an analog line I have in the office hooked up to an answering machine and success rate was 20%.
Are there any registry settings I can tweak to improve it?
geoff
Level 10
Level 10
There are Call Progress Analysis settings in 7.0 and they are described in the Outbound User Guide for 7.0 on page 3-15. It mentions that silence supression must not be engaged, so the dial peers should have "no vad". Then look at the table 3-1 for CPAJitterBufferDelay, CPAActiveThreshold, CPAAnalysisPeriod etc.
I am not sure what's in 6.0 so you would have to check.
Geoff
