IVR autoload
Oct 14th, 2009
Im configuring a AS5350 to force the load of audios (used by a call application) using the ivr autoload command.
the command follows:
#ivr autoload mode verbose retry 3 url tftp://ppsvr01.telenova.com/IVR/telenova/ivr_autoload-br-en-sp-ch.txt
#ivr prompt memory 13000
my ivr_autoload-br-en-sp-ch.txt:
#GC
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_000.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_003.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_004.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_005.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_006.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_007.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_008.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_009.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_010.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_011.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_012.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_013.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_014.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_015.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_016.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_017.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_018.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_019.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_020.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_030.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_040.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_050.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_060.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_070.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_080.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_090.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_1.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_2.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_3.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_account_blocked.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_and.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_ani.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_ani_confirm1.au
my call application loads the audio as follows:
call application voice ccp_goodcard set-location br 0 tftp://ppsvr01.telenova.com/IVR/telenova/br_goodcard11/
Thanks for the help.
paolo bevilacqua Wed, 10/14/2009 - 07:41
  • Hall of Fame,
    Founding Member
And the question is ?
lfplaimer Wed, 10/14/2009 - 08:08
Sorry, forgot about the question...
The question is.. its not working.
The audio does not loads in after a reload, only when I call the gateway (the firt call fails because the audio is not loaded, and the second call works, once he loaded the audio in the first call)
paolo bevilacqua Wed, 10/14/2009 - 08:13
  • Hall of Fame,
    Founding Member
Seems like a bug, you can try upgrading IOS or live with this minor problem.
lfplaimer Wed, 10/14/2009 - 08:18
Is the configuration correct ?
I want to be sure about it before update my IOS.
paolo bevilacqua Wed, 10/14/2009 - 09:11
  • Hall of Fame,
    Founding Member
The "call application" are obsolete, use "aaplication" and "service". Not sure about "ivr autoload".
