Is it possible to view individual SSL-proxy service usage (TPS)?
Oct 14th, 2009
Can the ACE provide any detail above and beyond just the overall ssl-connection rate for a particular context?
I have an ACE with two contexts and multiple ssl-proxy services configured within each and it would be really helpful to know the ssl-connection rate associated with each service (current, average, peak, etc) as I've got the issue where the SSL resource limit for one of the contexts has been reached and I don't know which service has jumped up in usage;-
Resource Current Peak Min Max Denied
ssl-connections rate 0 250 250 250 351
I can set up custom MIB pollers based on OID values within our SolarWinds network monitoring system so even if the information isn't directly available through the ACE CLI but has an associated OID I'd be grateful for the info if any one knows it (or even just the OIDs that contain the connection rate values from the 'sh resource usage' command so I can graph the overall usage against date/time within SolarWinds).
Gilles Dufour Wed, 10/21/2009 - 02:13
I do not know the OID to poll the service-policy info.
But if you do a 'show service-policy ' at regular interval and compare the hitcon, you can compute the connection rate for each service policy individually.
bgfl-tech Wed, 10/21/2009 - 02:49
Not quite the simple solution I was hoping for but thank you for the advice.
