Rob Huffman Wed, 10/14/2009 - 08:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
I'm not sure what you are running for VM but in many systems the default is # (pound key) to Skip Greeting. Let us know what you have @ your end.
Cheers!
Rob
kelvin.blair Wed, 10/14/2009 - 10:12
  • Silver, 250 points or more
If I recall.. ## is go to end of message..
Let me know if this helps..
Rob Huffman Wed, 10/14/2009 - 10:16
  • Hall of Fame,
    Founding Member
Hi Michael,
This behaviour is based on the "Caller Input" section of the User Template that is used to create the mailboxes.
To Specify Caller Input Settings on a Subscriber Template
Step 1 In the Cisco Unity Administrator, go to any Subscribers > Subscriber Template > Caller Input page.
Step 2 Select a key from the Caller Input Map or from the keypad.
Step 3 Select an action.
Step 4 Indicate whether to lock the key to that action.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusag210e.html#wp1048136
So, you need to Lock the # key to "Skip Greeting"
Cheers!
Rob
