7845H MCS
Answered Question
Archive Management attempts to collect configs from the CallManagers. Is there a way to tell it not to?
Correct Answer by Joe Clarke about 7 years 9 months ago
Not using the system config collection job. It will attempt to archive the config for every managed device. However, you could disable this job, and instead configure a Sync Archive job using the Group Selector. When you create this job, select the Group Selector radio button above the device selector, then choose the groups you wish to archive. As new devices are added, they will automatically be included so long as they fall into the selected group(s).
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 10/14/2009 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
