Voicemail problem on hub and spoke UC500s
Oct 14th, 2009
If one of the spoke sites calls an extension of a user at the hub and tries to leave a voicemail, they get disconnected.   I had them call the hub voicemail extension (500) and it rings busy.    Does the spoke locations need the voicemail dial-peer added for the hub location and visa versa?
Steven DiStefano Wed, 10/14/2009 - 09:11
  • Blue, 1500 points or more
Hi Brandon,
Check your Voice Service Voice configuration to make sure the following two statements exist:
no supplementary-service H450.2
no supplementary-service H450.3
This should allow call control at the terminating office site so you can access that sites Voice mail.
let us know.
Steve
brandon.kallas Wed, 10/14/2009 - 09:22
The spoke site had this configured, but the hub site did not.  I added the two statements, but it did not fix the problem.    Still when you call that user's extension and when it goes to voicemail, you start to hear "Sorry..." as if it's trying to play the voicemail greeting, but then disconnects.   Also if you dial the voicemail extension directly it rings busy.
Steven DiStefano Wed, 10/14/2009 - 09:34
OK, so this sound like the Voice Mail is not working at that site at all?  In other words, do local calls to voice mail work in that site?
brandon.kallas Wed, 10/14/2009 - 09:42
Yes, when you call an extension at the hub site locally, it works with no problems.   Also when you dial 500 it goes directly to that users voicemail box.
Steven Smith Wed, 10/14/2009 - 09:43
  • Gold, 750 points or more
What are the IP addresses at the sites (including the CUE subnet)?  Does voice (RTP) go across the tunnels?
What version of IOS are you running and CUE are you running?
brandon.kallas Wed, 10/14/2009 - 09:56
Yes, both voice and data go across the tunnels.
Spoke Site: IOS: 12.4(11)XW9  CUE: 3.2
Hub Site: IOS: 12.4(20)T2  CUE: 3.2
Hub site has a SIP connection, and here is the Access List for the SIP source group
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit xx.xx.xx.xx  <-- Cbeyond SIP
access-list 2 permit 192.168.254.0 0.0.0.255   <-- Local Data
access-list 2 permit 10.1.3.0 0.0.0.255   <-- Spoke Voice 1
access-list 2 permit 192.168.253.0 0.0.0.255    <-- Spoke Voice 2
access-list 2 permit 10.1.2.0 0.0.0.255    <-- Spoke Voice 2
access-list 2 permit 192.168.252.0 0.0.0.255   <-- Spoke Data 2
access-list 2 permit 10.1.1.0 0.0.0.255   <-- Local Voice
access-list 2 permit 10.1.10.0 0.0.0.3    <-- CUE
access-list 2 deny   any
Steven Smith Wed, 10/14/2009 - 13:02
Can you do a debug ccsip messages at the hub site and the remote site to capture a call?
Does this happen both ways?  Hub leaving a VM on a spoke and spoke leaving a VM on the hub?
brandon.kallas Tue, 11/10/2009 - 14:58
I was able to get this working, and seemed to work fine.   But then it stopped working again (when you call a user at the destination location and when the voicemail picks up, it disconnects you).   Here are the dial-peers for the source location (McIntosh) as well as the destination location (Broomfield).   When it was working, you could leave a message, but the DTMF-tones were not being recognized for selecting the available options for message delivery.
I have attached the debugs for "ccsip messages" and "voice ccapi inout" at the destination (Broomfield)
McIntosh Location (10.1.2.1) = Source
Calling number = 370
dial-peer voice 400 voip
destination-pattern 1[0-7].
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 403 voip
destination-pattern 500
codec g711ulaw
Broomfield Location (10.1.1.1) = Destination
Voicemail extension = 500
Called Number = 120
dial-peer voice 303 voip
incoming called-number 500
codec g711ulaw
dial-peer voice 2000 voip
description ** Xfterto VM **
translation-profile outgoing xfertovm
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
CUE
ccn subsystem sip
gateway address "10.1.10.2"
end subsystem
MICHAEL JOHNSON Wed, 11/18/2009 - 18:52
  • Bronze, 100 points or more
Are your CUE IP addresses different at each site? 10.1.10.x or are they both the same 10.1.10.1 and 10.1.10.2?
Maulik Shah Tue, 11/17/2009 - 16:10
  • Silver, 250 points or more
Need to check the config under voice service voip in Broomfield. Below is what CCA Multi Site Manager configures and should be the same on the sites:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
sip
  no update-callerid
This doc may help as well to compare CLI
https://supportforums.cisco.com/docs/DOC-9652
brandon.kallas Wed, 11/18/2009 - 15:38
Here are the configs for both sites, also the TAC Engineer stated that it could be because McIntosh location is running XW9 and Broomfield is running 20T2.  I just upgraded Broomfield to 20T4 and it still does not work.
Broomfield:
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
   localhost dns:sipconnect.den0.cbeyond.net
  no update-callerid
McIntosh:
voice service voip
sip
David Trad Wed, 11/18/2009 - 18:36
  • Cisco Designated VIP,
    2013 Small Business
Hi Brandon,
I just finished going through this problem myself, a couple of things to look at here that we did to resolve it:
  1. Make sure that Transcoding is working fine, CUE only likes to work as G-711 uLaw
  2. Use the Voice-Class codec directive, run two of them, in Voice-Class Codec 1 have only uLaw in there, in #-2 have all your other ones, then apply this code to your WAN dial-peers, preferrably use #-1 first, and then if that does not work try #-2
Check your packet loss over the WAN link, i have also found that heavy packet loss can prevent connectivity over WAN to CUE, it is a real pain in the...You kow what :)
Good luck with resolving the problem.
Cheers,
David.
MICHAEL JOHNSON Wed, 11/18/2009 - 18:46
I can't believe TAC tried to blame IOS version mismatch and recommend an IOS upgrade...just kidding. I hear that everytime....
MICHAEL JOHNSON Wed, 11/18/2009 - 18:50
Do you have the SIP trunk tied to the interface (typically VLAN1) in the config on each destination?
Sorry don't have the command in front of me.
David Trad Wed, 11/18/2009 - 18:53
    2013 Small Business
And whilst we are at it with the bombardment of questions :)
Is your site-2-site calling done via H.323 or SIP??
Cheers,
David.
MICHAEL JOHNSON Wed, 11/18/2009 - 18:56
and....i can't keep up with you David...you must type 100 words a minute...
David Trad Wed, 11/18/2009 - 19:11
    2013 Small Business
I have never counted but i would imagine it is close to that or more
Cheers,
David.
