IP Communicator Integration with Exchange Contacts
Oct 14th, 2009
Hello All,
Is there anyway to have IP Communicator integrate in some way with exchange so that you can dial your exchange contacts from IP Communicator? Thanks
Jason
Tommer Catlin Wed, 10/14/2009 - 12:00
  • Green, 3000 points or more
If you are talking about the GAL, the GAL is not supported. But your local contacts within your Outlook is supported when using the click to call widget or CUPC.
You may also try and use TSPs, but always seem to have issues with those.
