LMS3.2 (RME 4.3.0) 3560v2
Oct 14th, 2009
Does anyone have an update on the timeline of support for 3560v2 switches in RME4.3
Joe Clarke Wed, 10/14/2009 - 09:38
This device is supported now in Cat3560 package version 7.1. However, we have an issue. It appears that the Cat3560 package which came with RME 4.3.1 reports itself as 7.1, but does not include support for this device. The Cat3560 7.1 package on Cisco.com right now DOES support this device. I'm trying to get this sorted out now.
rcierny Thu, 10/15/2009 - 07:17
Standing by for an update.We did a large deployment of 3560v2s only to be unpleasantly surprised by (lack of) LMS support...
Joe Clarke Thu, 10/15/2009 - 08:00
If you have RME 4.3.0, you can go to Common Services > Software Center > Device Update, and download and install all available updates for Common Services and RME. That will give you 3560v2 support. If you have RME 4.3.1, you will need to wait a little while longer. New packages are forthcoming.
rcierny Fri, 10/16/2009 - 05:43
we are running 4.3.0
I have succesfully installed all packages except LibInventory 3.1.3
When trying to install I get error message:
Number of Packages Selected for Install : 1
For Product(s) : Resource Manager Essentials
Install Invoked by user : rcierny
The Package(s) Selected for Install :
ERROR: Error while installing (LibInventory): C:psu_download
meLibInventory.zip cannot be installed because, the current mdf version:1.30 is LESS THAN the minimum required mdf version:1.32
No package(s) to install for : Resource Manager Essentials
3560v2 devices still not showing in CS
rcierny Fri, 10/16/2009 - 07:49
30. Cat3560 7.1 Cat3560 device package
What exactly do I need to download?
Joe Clarke Fri, 10/16/2009 - 09:02
This is the correct package, and I know it has the sysObjectID for this switch. Post the list of contents under NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs.
technet1 Thu, 10/29/2009 - 04:39
Hi jclarke. Do have any new infos when the new packages are available? I have 4.3.1 and i'm also waiting for 3560v2 support.
