ACS RDBMS adding NDG with Shared Secret
I have an ACS 4.2 on a SE 1113 and I am using RDBMS to add Network Device Groups. I am able to create the group, but I would like to set the Shared Secret for the group. I am using the action code 250 to add the group but I can not see a way to set the Secret. I can modify the Secret after creating the group using the GUI but it would be better to do it all with RDBMS. Are there any other action codes that can be used on NDGs?
Thank you.
Overall Rating: 4 (1 ratings)
darpotter Thu, 10/15/2009 - 00:11
  • Silver, 250 points or more
Per NDG shared secrets came after NDG addition via dbsync. It looks like this has not been retro-fitted to dbsync.
This is quite typical as dbsync is the poor unloved child of ACS.
