10-14-2009 09:43 AM - edited 03-04-2019 06:22 AM
We are using cat 6506 with single SUP engine 2 now we planned to redunant SUP in that CAT 6506
whether the second SUP2 can be installed in Slot 1 and 2
and also when insert the second SUP 2 the module goes to below state
2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE
2 Catalyst 6000 supervisor 2 (Cold) WS-X6K-S2U-MSFC2
is this will be a problem when active goes down?
any difference between Slot0 and disk0
because i need to configure the same as existing Active SUP
thanks
10-14-2009 10:16 AM
Hello Vinoth,
the two supervisors look like to have different part numbers.
May you confirm you have two supervisor2 with MSFC2?
post a sh module for checking this.
Also IOS image should be the same to be able to use a redundancy strategy RPR or SSO.
Also is the chassis in Native mode or it is still in Hybrid mode?
When all parameters match the standby supervisor receives configuration from active supervisor.
You need to deploy first the right IOS image. (or catos image+ MSFC image if in Hybrid mode)
Hope to help
Giuseppe
10-14-2009 10:22 AM
Thanks for your reply
Mod Ports Card Type Model
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE
2 2 Catalyst 6000 supervisor 2 (Cold) WS-X6K-S2U-MSFC2
3 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX
4 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC
5 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX
Mod MAC addresses Hw Fw Sw Status
1 0009.1246.baf8 to 0009.1246.baf9 4.3 7.1(1) 12.2(18)SXF1 Ok
2 0006.d65e.45d0 to 0006.d65e.45d1 5.0 7.1(1) 12.2(18)SXF1 Ok
3 0014.6a6f.2720 to 0014.6a6f.274f 1.1 7.2(1) 8.5(0.46)RFW Ok
4 0002.7e24.c85c to 0002.7e24.c863 1.3 5.4(2) 8.5(0.46)RFW Ok
5 000d.29db.3b82 to 000d.29db.3bb1 4.0 7.2(1) 8.5(0.46)RFW Ok
Mod Sub-Module Model Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 3.4 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 2.5 Ok
2 Policy Feature Card 2 WS-F6K-PFC2 3.4 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 2.6 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
and also can we change the redunancy mode from RPR+ to SSO when the active and standby SUP's running in live
10-17-2009 09:17 AM
The default redundancy mode is RPR so that's why you see the 2nd SUP in cold state. In this mode the standby SUP is not completely booted.
Yes you can change the redundancy mode on a live chassis. It will reload the standby SUP.
Laurent.
