Hello Ciscoees!!!
Oct 14th, 2009
Hello all, I'm sure this is a very easy question, but obviously I am a noob.  I have a few 1841's that I have to configure for our company.  My question, where can I find what the latest firmware and IOS this router supports.  More questions to come! :)  Thanks in advance.
Luis
Glenn Quesenberry Thu, 10/15/2009 - 10:58
  • Cisco Employee,
Luis,
     You can use the Software Advisor online tool to help you determine what IOS version is available for your hardware.  You must provide some specific information about your hardware and configuration and then the tool will inform you what IOS versions are applicable to choose from.  You can fine the Software Adviser by clicking here, then look on the page under "Software Tools" (near the center of the page, towards the right-side a bit).  Click the link for "Software Advisor" and your're off and running!
Good Luck!
Best Regards,
Glenn
