IGX statistic collection
Oct 14th, 2009
I have a question regarding IGX ports statistics collection.
We have deployed a number of IGXs long time ago, and the statistics file are received from each node hourly. Everything is working fine. But recently, we turned up two new ports on two of switches, and the ports are up, and they are transmitting and receiving data. The problem is that the port stats and trunk stats for these two particular ports are not shown in the statistics file. The switches still send the statistics files every hour, and all other ports, trunks stats are in the files. But only miss the stats for these two new ports. I do see the connection stats, which are using these two ports, in the stats files.
Could anyone tell me what should be done to include these two ports stats in the statistics files. I tried on2 command to disable and re-enable the port stats sampling, but it didn't help.
Any ideal or suggestion is appreciated.
Thank you in advance.
Qing
