External Aerial for Uc500
David Hornstein Wed, 10/14/2009 - 19:00
Hi Damien,
There is a pretty good guide at the following location;
I'm guessing from your brief description you wish to extend the internal wireless AP found inside the UC5X0W series.
You would need a TNC patch cable and appropriate antenna  that worked in the 2.4Ghz frequency range.
eg.  Maybe 20' patch cable p/n  AIR-CAB020LL-R and maybe with a p/n AIR-ANT2485P-R patch antenna.
But, please choose the appropriate cable length and appropriate antenna to meet your customers needs.
regards Dave
