I am trying to get my lab going as was wondering if can load the server with windows 2003 , and then load the NFR UCCX 7.X..
Where does MSDE get loaded? Is it on the IPCC code disk or do I absolutley have to have the Cisco windows 2003 base code?
The issue is I cannot seem to find the 2003 code that came with the NFR kit and need to get IPCC running. I don't need HA.
Overall Rating: 5 (1 ratings)
csshenoy80 Thu, 10/15/2009 - 07:57
The MSDE gets installed when you install the UCCX software, by default.
You need to have the windows 2003 from Cisco. The main difference is the Windows directory, which is "Windows" in windows 2003 generic install and "winnt" in the Cisco customized windows 2003 CD.
You can find the details for the customization you need to tweak using the generic windows 2003 by searching Netpro, since this has already been posted earlier.
