SWVMS16 Video Monitoring System
Oct 14th, 2009
I have downloaded the 1.2 version of this software and reinstalled it twice, but when I try to open the Main Console, enter my user name and password, I get "Missing or corrupted resource files. Please reinstall the system to solve this problem."
Reinstalling is definitely not working, any ideas?
makirby Wed, 10/14/2009 - 19:54
Thank you Steve, I used both methods for resetting the password. Both result in the same error message.
I have also attempted a restart of the XP OS...
Steven DiStefano Wed, 10/14/2009 - 19:58
Try one more thing for me.  Change the resolution of the PC to something at or over 1280 x 800.
If that doesnt work, open a case with SBSC.
Joachim Kern Fri, 10/16/2009 - 10:36
Hi, max resolution on my PC is 1280 x 710. I have the same issue on two machines. What can I do ?
Steven DiStefano Wed, 10/21/2009 - 05:39
try various resolutions to see if it helps.    SWVMS16 datasheet says:
Video card
ATI Radeon 9200, NVIDIA GeForce FX-5200, Intel 945G/965G,  or above (ATI is recommended)
