how to get a read only access of cucm 7 database
Oct 14th, 2009
Hi, my customer uses to have ODBC access to CUCM PUB 4.23 SQL Database. since we are in the process of upgrading their cluster to 7. and database changes to IDS,they are afraid they will lose connection. is there a way to provide similar read access to DB in CUCM 7 ? thanks in advance
Overall Rating: 4 (1 ratings)
ilbobleung2009 Thu, 10/15/2009 - 05:50
Can someone please comment on this one or point to the right direction? thanks
James Hawkins Sat, 10/17/2009 - 08:36
  • Blue, 1500 points or more
You can get the Informix ODBC drivers from the link below:
http://ciscounitytools.com/Applications/CxN/InformixODBC/InformixODBC.html
The linked site provides the drivers to support the audio text manager application for Unity Connection 7.x which runs on the same OS as CUCM 7.x.
Not sure how much this will help you but it may be a start.
Jonathan Schulenberg Sat, 10/17/2009 - 10:16
  • Cisco Designated VIP,
    2017 IP Telephony
Informix access to UCM is highly restricted. You can execute some commands through the restricted CLI. For remote operations the customer will need to utilize the AXL APIs.
Cisco Unified Communications Manager XML Developers Guide Release 7.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/7_1_2/AXL_DevGuide.html
If the customer is access CDR records, the new process for this is to have the cluster SFTP the CSV files to another location for parsing.
Cisco Unified Communications Manager CDR Analysis and Reporting Administration Guide,
Release 7.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/CAR.html
