IP SLA tracking for MGCP protocol
Oct 14th, 2009
who could provide some example to monitor the MGCP protocol, like use
IP sla xx
tcp-connect blah blah
or some example regarding how to setup UDP or ICMP jitter
thanks in advance
Giuseppe Larosa Wed, 10/14/2009 - 22:51
  • Hall of Fame,
    Founding Member
Hello Guy,
sh mgcp statistics on router acting as voice gateway provides already a lot of useful data.
So probably an IP SLA on MGCP may be not needed in real world.
Also you don't need it to trigger SRST for example.
To be noted MGCP is a protocol based on UDP and not on TCP.
depending on your IOS version, I suppose you have a new 12.4T on your device you can refer to the following document:
this a chapter from 12.4T IP SLA configuration guide
http://www.cisco.com/en/US/docs/ios/ipsla/configuration/guide/sla_udp_jitter_voip_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
study_voip Thu, 10/15/2009 - 05:16
thx for you reply.
MGCP working on both TCP and UDP, and D channel backhaul using TCP, so want to track the TCP connection and setup some conditions using IP SLA to monitor the MGCP connection
or if you have some UDP/ICMP jitter example, I can setup that as well
thx again
Giuseppe Larosa Thu, 10/15/2009 - 05:24
  • Hall of Fame,
    Founding Member
Hello Guy,
good point D channel backhauling uses a TCP session you are right on this.
for example of SLA read the document at the link I've provided
Hope to help
Giuseppe
study_voip Thu, 10/15/2009 - 05:34
thx for you reply.
thx again
