Warning message
aslam.bajwa Sun, 10/18/2009 - 21:59
Hello ,
where i can find this field "dateTimeConnect" in the callmanager ?
regards ,
virverma Mon, 10/19/2009 - 16:46
  • Silver, 250 points or more
You will find the value in a CDR file
aslam.bajwa Tue, 10/20/2009 - 01:24
i would appriciate if you can tell me the exact path where i need to make changes to get local time on CDR ....
i am using below command but dont know exactly wot to do ?
admin:file list activelog cm/cdr_repository/car/
i have used options with file list activelog cm/cdr ?
but still coudnt reached at "datetimeconnect " field
many thanks advance
Jaime Valencia Tue, 10/20/2009 - 07:40
  • Cisco Employee,
  • Hall of Fame,
    2011
As already explained since the 1st reply:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cdr_defs/5_x/cdr504.html
[Cisco Unified CallManager 5.0 Call Detail Record Definitions]
The field "dateTimeConnect" does not account for any timezone information and it only records the time stamp
in GMT.
If you use CAR it uses the server timezone to adjust when running reports, if you use any 3rd party billing it should do this as well.
You CANNOT change the fields in the DB to show what you want.
java
if this helps, please rate
http://www.cisco.com/go/pdihelpdesk
aslam.bajwa Thu, 11/05/2009 - 00:09
Hello ,
i have attached screen shot of CDR search window there is clearly mentioned that we can only search CDR reports in GMT time . my question is that , is there anyway to search CDR reports in local time ? or can u send me the link of any cisco document where i can see and confirm that we can have CDR reports in local time ..
many thanks
