Unable to import PKCS12 certificate file to ACE module
Answered Question
Oct 15th, 2009
  • Bronze, 100 points or more
I'm currently in the process of replacing my CSS-appliances with the ACE module. So far everything's been smooth, but when I'm trying to import a certificate file to the respective context using the "crypto import"-command, ACE can't recognize the filetype, it's just marked as UNKNOWN. On the CSS I had to specify PKCS12 as the fileformat, but this is apparently not an options on the ACE. Does anyone know the equivalent commmand on how to import a PKCS12-file to the ACE?
Thankx
/Ulrich
PS! I haven't created a cert chaingroup, as I was told this would not be necessary.
Correct Answer by ciscocsoc about 7 years 8 months ago
Hi Ulrich,
Short answer is you cannot import PKCS12 format. You'll need to extract the component parts into PEM format outside of the ACE and then use crypto import.
You will also need a chaingroup unless this is a self-signed certificate. Again any intermediate and root certificates will need to be in PEM format.
Cathy
Overall Rating: 5 (1 ratings)
Correct Answer
ciscocsoc Thu, 10/15/2009 - 07:22
  • Silver, 250 points or more
Hi Ulrich,
Cathy
UHansen1976 Fri, 10/16/2009 - 01:56
Hi Cathy,
Thanks a lot.
/Ulrich
