Cisco VPN Clietn and Split Tunneling
Oct 15th, 2009
I have setup a new Cisco VPN profile for a customer where they can ony conenct to one server behind my ASA. I have also turned on "Split Tunneling" so he can access his local LAN whie connected, all this works fine.
He has mentioned he can't access the Internet while connected to the VPN, how can I get he to use his local Internet and not tunnel over the VPN to try and access the VPN?
I have excluded 0.0.0.0 on the "split Tunneling", should this be enough?
Herbert Baerten Thu, 10/15/2009 - 02:46
  • Cisco Employee,
Instead of excluding 0.0.0.0, include only the address(es) the customer should be able to reach over the tunnel.
hth
Herbert
