Wr mem fails on C6K
Oct 15th, 2009
C6500-SUP720-3B#wr
%No memory available: Update of NVRAM config failed!
has anyone a explanation ? the Configuration is not that big it should definitly fit into the NVRAM, but the box is low on Memory :
Processor Pool Total: 391036432 Used: 366100000 Free: 24936432
I/O Pool Total: 67108864 Used: 10437776 Free: 56671088
Giuseppe Larosa Thu, 10/15/2009 - 04:44
  • Hall of Fame,
    Founding Member
Hello Emanuael,
check with sh users
if there are other vty sessions open
there might be a sh conf pending on some other vty.
the show proc mem doesn't show the amount of memory in filesystem nvram:
do
dir nvram:
example from a C6500 with sup720B
dir nvram:
Directory of nvram:/
1918 -rw- 149823 startup-config
1919 ---- 24 private-config
1920 -rw- 149823 underlying-config
1 ---- 4 rf_cold_starts
2 ---- 47 persistent-data
3 -rw- 0 ifIndex-table
1964024 bytes total (1811053 bytes free)
Hope to help
Giuseppe
nsn-amagruder Thu, 10/15/2009 - 05:43
service compress-config may help if the last suggestion show the config in NVRAM is large or almosted used.
e.hoehn Thu, 10/15/2009 - 05:52
Hello Guys,
Thanks for the responds, but it actually does ont help ...
here the output (and as I sayed, the config is not that larg ...)
C6K-SUP720-3B#dir nvram:
1918 -rw- 29322 startup-config
1919 ---- 7175 private-config
1920 -rw- 29322 underlying-config
2 ---- 49 persistent-data
3 -rw- 3460 ifIndex-table
1964024 bytes total (1921331 bytes free)
C6K-SUP720-3B#sh conf | i Using
Using 29322 out of 1964024 bytes
Does anyone has other suggestions ?
