ACNS connect control + qos
Oct 15th, 2009
  • Bronze, 100 points or more
I need to control who is able to connect to ACNS (based on ip), preferably per stream or program.
1) The only thing i found is to put an ACL on the interface do deny some IP addresses.
a) Is there another method ?
b) Can you 'deploy' the ACL method via the content device manager or does it need to be applied locally ?
2) Is it possible to color the streaming packets (unicast and multicast) with a certain DSCP value, per program, via the CDM (centrally) ? Right now, the only solution i have found is via a service-policy map on the physical switch port.
david-webb Thu, 10/15/2009 - 06:28
Gnijs, if these are multicast streams, could you manage this through unique multicast addresses and applying ACLS based on these? DW
