Ringer Volume: Multiple DNs
Oct 15th, 2009
I know you can change it for the entire device by using the Volume +/- when the handset is on hook. I also see where you can configure this under the Line appearance for Ringer Setting (Phone Idle & Active) to Disable, Flash, etc.
Is it possible to selectively adjust ringer volume per line on one device that has multiple DNs assigned to it?
Thanks.
Craig L. Pollitt
testeven Thu, 10/15/2009 - 07:29
  • Cisco Employee,
Hi!
The ring volume/level is saved on the phone's memory, therefore it will apply to the device as a whole, not on a line basis.
HTH!
Teresa.
If it helps, please rate.
