Duplicate TCP SYN from inside ??
Oct 15th, 2009
Hello all,
A user can not send e-mail using outlook, but he can retrieve his email.
I checked the ASA 5505 log and I found a message:
4 Oct 15 2009 09:07:18 419002 192.168.106.2 209.210.**.1*0 Duplicate TCP SYN from inside:192.168.106.2/1323 to outside:209.210.**.1*0/25 with different initial sequence number
192.168.106.2 is his computer ip address and 209.210.**.1*0 is the smtp server.
Does the ASA 5505 block the connection to the SMTP server? Please help!
Thank you.
davidwu2007 Thu, 10/15/2009 - 10:59
Verizon, the Internet Services Provider, had changed the SMTP port from 25 to 578. Reconfigure MS Outlook SMTP port to 578 and the problem is gone.
