CAS OOB compatability with CAS In-BAND
Answered Question
Oct 15th, 2009
We currently have a CAS/CAM (3310s) deployment in production. The CAS is in a IN-band deployment for VPN users and we are considering adding a OOB CAS for LAN guest access.We are running
version 4.6.1.
The question is can we mix the types of CAS (in-band and OOB) on the same CAM??
Pedro
Correct Answer by Faisal Sehbai about 7 years 8 months ago
The versions have to be the same, but yes you can have a CAM manage an OOB and IB CAS at the same time.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Thu, 10/15/2009 - 06:48
  • Gold, 750 points or more
HTH,
Faisal
