redial softkey not working
robhawker
The phones display the redial soft-key but it doesn't redial when you hit it. I have read something in regards to ephone-templates, but i am not sure if this is the issue as the phone shows the button. Do the templates add functionality if the soft-key is already there or does it just allow you to display the soft-key? It does not work on any phones in the system
info:
phones: 7912, 7940, 7912
system:
Cisco Unity Express Version 3.1
About Cisco Unified CallManager Express
Operating System: Cisco Internetwork Operating System. Cisco IOS (tm) C2800NM
Cisco IOS Software: C2800NM-IPVOICEK9-M
Software Version: 12.4(15)T3 / CME 4.1(0)
Feature Package: IP|VOICE|SSH|3DE
6 Replies 6
testeven
Hi!
This can be related to the interdigit timeput. Try to reduce the "timeouts interdigit" under telephony service to 3 seconds, by default it's
10 seconds.
HTH!
Teresa.
If it helps, please rate.
Regards, Tere. If you find this post helpful, please rate! :)
I checked that. It was set to 4. But they were also complaining that the dial time out was to short so i set it to 6.
When the redial key is pushed it comes up with a blank window so you can dial a number. It is not bringing up the last call made.
Is there a chance you can reload the router? Seems an issue with the telephony-service itself. A similar case was solved with a reboot.
I reloaded it. I am getting an error that says "softkey not active"
little more info:
the redial works on internal extensions but not when you try and redial and outside number
Here is some info on the phones if it helps
7912
app load: CP7912080001SCCP051117A software: 8.0.1(051117A)
7940
app load: P00308000400
Software: 8.0(4.0)
7960
software: 8.0(4.0)
