5540 stuck in 79% mem usuage
Oct 15th, 2009
Primary ASA 5540 from 10/08/2009
went up memory utilization from 600mb to 800mb out of 1GB total memeory
No matter what time of the day - its stuck
I disabled logging and other couple memory related twiks but does not help
I don't want to reboot until i know wht caused it
we are running 8.0(4) 28 image
there was no significant change done on 10/08/2009
Any comments please
Yudong Wu Thu, 10/15/2009 - 13:33
  • Gold, 750 points or more
1. If you have a baseline, check "show xlate", "show conn count" to see if they are big diff from your baseline.
2. You can check the traffic load to see if a interface / host has a alot traffic.
"show traffic", "show local-host"
3. There might be a memory leaking in certain process. In this case, you might reload the box and then monitor memory usage to see if there is a process keep using more and more memory. "show memory detail".
