7200 bandwidth points help
Oct 15th, 2009
Hello All,
I have a 7206VXR router. I have a small confusion with the bandwidth points that I am getting when i Give a show vers.
show version (chopped):
Cisco IOS Software, 7200 Software (C7200P-IPBASE-M), Version 12.4(4)XD10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 28-Dec-07 14:12 by karnagar
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-BOOT-M), Version 12.4(4)XD10, RELEASE SOFTWARE (fc2)
System image file is "disk2:c7200p-ipbase-mz.124-4.XD10.bin"
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 600 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
issue:
mb2 bus shows 600 points as current config:
now the cards i have is slot 2,4 and 6 are :
show diag of 2,4 and 6 :
Slot 2:
Dual Port FastEthernet (RJ45) Port adapter, 2 ports
Port adapter is analyzed
Product (FRU) Number : PA-2FE-TX
Top Assy. Part Number : 800-08350-06
EEPROM format version 4
Slot 4:
Fast-ethernet (TX-ISL) Port adapter, 1 port
FRU Part Number: PA-FE-TX
Slot 6:
Mx serial Port adapter, 4 ports
EEPROM contents at hardware discovery:
Hardware revision 1.0
Part number 73-1577-04
FRU Part Number: PA-4T+=
so slot 2 : PA-2FE-TX(400 ponits but one port shut down so shld be 200)
slot 4: PA-FE-TX = 200
slot 6 : PA-4T+ = 0
so total should be 400 but show version shows 600, one port in the slot 2 PA-2FE-TX is shut down now.
show ip int brief :
GigabitEthernet0/1 10.x.x.x YES NVRAM up up
FastEthernet0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0/2 10.x.x.x YES NVRAM up up
GigabitEthernet0/3 10.x.x.x YES NVRAM up up
FastEthernet1/0 10.x.x.x YES NVRAM up up
FastEthernet1/1 10.x.x.x YES NVRAM up up
FastEthernet2/0 unassigned YES NVRAM administratively down down<<< ITS DOWN
FastEthernet2/1 10.x.x.x YES NVRAM up up
Ethernet3/0 x.x.x.x YES NVRAM up up
Ethernet3/1 unassigned YES NVRAM administratively down down
Ethernet3/2 unassigned YES NVRAM administratively down down
Ethernet3/3 unassigned YES NVRAM administratively down down
FastEthernet4/0 10.x.x.x YES NVRAM up up
Serial5/0 10.x.x.x YES NVRAM up up
Serial6/0 10.x.x.x YES NVRAM up up
Serial6/1 unassigned YES NVRAM administratively down down
Serial6/2 unassigned YES NVRAM administratively down down
Serial6/3 unassigned YES NVRAM administratively down down
please help, why I am getting a 200 point extra?
prakadeesh
Giuseppe Larosa Thu, 10/15/2009 - 07:34
  • Hall of Fame,
    Founding Member
Hello Prakadeesh,
I may be wrong but I think BW points are calculated on PA type not how many ports are active and configured.
https://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_presentation09186a008009184d.pdf
also you need to consider that ports on the NPE uses BW points on one bus and this can make the difference you see.
For this reason, someone prefers 7204 chassis over 7206 chassis
Hope to help
Giuseppe
kzhen Thu, 10/15/2009 - 11:17
PA-2FE-TX is 400 bandwidth points, it doesn't mean you shut down one port, and it will decrease to 200. You can try to shut down both ports, it still 400.
Ken
