Empty Syslog Analyzer Customer Summary Report
Joe Clarke Thu, 10/15/2009 - 08:19
The Custom Summary Report lists all syslog messages which match your defined syslog custom reports. What custom reports do you have defined? What are those report parameters? What syslog messages do you see in the standard 24 hour report?
I should have also mentioned that the report did produce data as of about a week ago, but has suddenly stopped. We have a daily syslog report that emails out events etc. We have quite a few reports from both the standard set and our customized ones.
Custom Report Names:
1. Configuration Changes Report
2. CPU Hog Report
3. Duplicate IP Address Report
4. Environmental Monitor Report
5. Flash Memory Error Report
6. IOS Firewall Application Level Intrusion
7. IOS Firewall Denial of Service
8. Memory Allocation Failure Report
9. PIX Denial of Service Report Incoming TCP or UDP Connections
10. PIX Denial of Service Report Outgoing TCP or UDP Connections
11. Reload Report
12. Severity Level 0 and 1 (Emergency/Alert messages) Report
13. Severity Level 2 (Critical messages)
14. uBR Severity Level 0 and 1 (Emergency/Alert messages) Report
15. uBR Severity Level 2 (Critical messages) Report
16. Embedded Event Manager
17. Generic Online Diagnostics
18. IP SLA Threshold violations
19. Broadcast Storm Detection
20. Duplex Mismatch
The standard 24hr report has all the data I would expect in syslog...
Joe Clarke Thu, 10/15/2009 - 10:44
Syslog data periodically ages out of the database. While the standard 24 hour report shows all available messages, these reports have specific match criteria which may not be met. This is why I asked for sample messages and the details of how each on of these templates is defined.
