10-15-2009 08:24 AM - edited 03-15-2019 08:05 PM
Does anybody know if the SIP CME supports g729 codec in voice register pool?
I mean you can put it there but my phones (which are both g729) cannot talk to one another, I hear silence (711 works fine). I tried implementing transcoder and having one phone g711 and another g729 and it is still acting strange...
Anyone knows of any known issues?
regards..
Pilat Goran
10-15-2009 08:28 AM
Which phones are these? If non cisco, you are on your own, if you can figure out the problem yourself all good, otherwise you're OOL.
10-15-2009 09:51 AM
They are 7940 and 7960 with P0S3-8-12-00. BTW what does OOL stand for?
IOS is 12.4.24T
regards,
10-15-2009 10:22 AM
Out Of Luck :)
Recommend you convert the phones to SCCP and they will work no fault.
10-15-2009 10:50 AM
I know it would work but I'm practicing at the moment on my lab so I wanted to see how this works...
Thanks anyway
cheers
