Warning message
NAC CAA provider
Answered Question
Oct 15th, 2009
Hi All,
I am building the NAC lab. first I have donwloaded CAA without external authentication server and only used localDB. everything worked fine. then I have added external auth server (AD LDAP). on auth test, it works fine. but when CAA pops up to login, it doesn't show external auth server and only shows localDB. I have reinstalled CAA, but it still doesn't show external auth server.
any idea would be very appreciated.
thanks
Alex
Correct Answer by Faisal Sehbai about 7 years 10 months ago
If you added AD SSO, that won't show up in the auth providers list. If you added a LDAP provider, that should show up after you enable it. To make sure you have it enabled, check the definition of your user pages and check mark the providers you want enabled.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Thu, 10/15/2009 - 10:48
  • Gold, 750 points or more
HTH,
Faisal
