ASA firewall versus Cat 6500 firewall modul.
Oct 15th, 2009
Hi all,
can someone send me doc. or give me
brief overview in diference of firewall ASA and firewall modul WS-SVC-FWM to Cat 6500?
Yudong Wu Thu, 10/15/2009 - 14:25
ASA can terminated VPN such as IPSec, WebVPN. But FWSM only have firewall feature.
You can go to cisco website and check related data sheet for more detail performance data.
gabrielgr Thu, 10/15/2009 - 23:03
Hi Kevin,
thanks for a. My question is, is it the same to use ASA and FWSM when I dont need VPN ending?
What is advantage FWSM and what ASA?
Panos Kampanakis Fri, 10/16/2009 - 04:20
More or less the "firewalling" features are similar.
There are minor differences depending on the specifics.
Also, one architectural difference is that the ASA performs operations in CPU whereas the FWSM does part of it in hardware and part on the Networks Processors and CPU it has.
Also, the ASA is more actively evolving and the FWSM is a mature and older product.
