Frame Relay Static Mapping and Inverse-ARP
Oct 15th, 2009
Ref 1. : Configuring Frame Relay, http://www.cisco.com/en/US/docs/ios/12_2/wan/configuration/guide/wcffrely.html#Disabling_or_Reenabling_Frame_Relay_Inverse_ARP
Ref 2. : CCNA ICND2, Official Exam Certification Guide, Second Edition, ISBN 158720181X
Ref 3. : Frame Relay Question, http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cd2b0f5/17#selected_message
Folks,
Is there any way on a router in a frame relay network to verify through an IOS command that Inverse-ARP has been disabled? Ref 2, the ICND2 book, on Page 500, second paragraph says, "The router disables Inverse ARP on a subinterface when the frame-relay map command is configured". There is no mention of this in the 12.2 command reference for 'frame-relay map' and 'frame-relay inverse-arp' commands. At Ref 3, the last post says that Inverse Arp needs to be manually disabled when statically mapping DLCI's to IP addresses. The topology being asked about seems to be point-to-point with subinterfaces. Ref 1, Frame Relay Question, doesn't mention anything about a disabled inverse arp either.
Your advice is appreciated.
Timothy
Marwan ALshawi Thu, 10/15/2009 - 15:32
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
inv-arp will be disabled if u use point-topoint subinterface
if u use the main interface or multipoint-point sub-interface
u need to disable it by using the command
no frame-relay invers-arp
good luck
if helpful rate
BOGDAN OVIDIU S... Tue, 10/20/2009 - 07:23
Hy,
To see if there is Invers-Arp you can do a: show frame-relay map and see if the DLCIs are dynamic.
For example:
sh fram map
Serial0/0/0 (up): ip 129.1.124.4 dlci 204(0xCC,0x30C0), dynamic,
broadcast,, status defined, active
Always when you have dynamic learned DLCIs you have invers-arp enabled.
Even if you statically define DLCIs (frame-relay map ip 1.1.1.1 102 broadcast) invers-arp is not disabled. There is only one time when invers-arp is disabled by default: point-to-point subinterface:
int s0/0
encapsulation frame-relay
int s0/0.1 point-to-point
frame-relay interface-dlci 102
sh fram map
Serial0/0.1 (up): point-to-point dlci, dlci 102(0xC9,0x3090), broadcast
All the best,
Bogdan
BOGDAN OVIDIU S... Tue, 10/20/2009 - 07:26
Hy again :),
and, of course, to disable invers-arp:
interface s0/0
ip add 1.1.1.1 255.255.255.0
no frame-relay inverse-arp
So, there is a second command to see if inverse-arp is disabled or not:
sh run int s0/0
All the best,
Bogdan
Peter Paluch Tue, 10/20/2009 - 07:46
  • Cisco Employee,
Tim,
There seems to be some misunderstanding in the book you are referring to about the Inverse ARP.
Having a static mapping on a Frame Relay interface does not disable the InverseARP for the entire interface. The mapping merely causes that the router never sends InverseARP requests out the DLCI that is used in a static mapping. After all, that would be an useless thing to do, as the mapping is already defined statically. However, if an InverseARP request is received on a DLCI that is used in a static mapping, the router will send an InverseARP response without any limitation.
The point-to-point subinterfaces behave in a very similar way. They do not send InverseARP requests themselves because that does not make sense - for a point-to-point interface, everything can be reached through a single DLCI associated with that interface so there is no point in asking for mappings dynamically. However, if a point-to-point subinterface receives an InverseARP request, it happily responds with an InverseARP reply.
It is not true that in order to use static mappings, it is required to deactivate the InverseARP. You can freely mix dynamic and static mappings on an interface. Usually, though, when a static mapping is used, often the InverseARP is deactivated in order to have firm control about which DLCIs will or will not be used. Also, having a bunch of static and dynamic mappings on an interface can be confusing and difficult to debug so most often, it is best avoided.
So to summarize the main points here:
1.) A static mapping does not deactivate the InverseARP per se. It only stops sending InverseARP requests and only for statically mapped DLCI in question. It does not prevent sending InverseARP requests for other (not statically mapped) DLCIs, and it does not prevent sending responses at all.
2.) A point-to-point interface does not send InverseARP requests but it may send InverseARP responses if it receives a request itself.
3.) Static and dynamic mapping can be combined on a single physical interface or multipoint subinterface.
4.) The InverseARP is completely deactivated with all requests and responses if and only if the command "no frame-relay inverse-arp" is entered on an interface or subinterface.
