10-15-2009 03:17 PM - edited 03-06-2019 08:09 AM
Is there a simple way to really verify that the cisco 3560 is a layer 2 or layer 3 switch? or is it actually dependent upon the ios image that it's running?
Switch model number is WS-C3560-48PS-S
Thanks.
Solved! Go to Solution.
10-15-2009 03:38 PM
3560 is L2/L3 switch
if you do not enable ip routing the switch will operate as L2
switch
use this command to make it L3
ip routing
to make only L2
no ip routing
good luck
if helpful rate
10-15-2009 03:42 PM
I would try and setup 2 gateways, connect 2 hosts and see if they can ping eachother;
example:
Int vlan 100
ip adress 10.10.10.1 255.255.255.0
no shut
conf t
int gi 0/1
switchport mode access
switchport access vlan 100
no shut
connect host 1 to gi 0/1
repeat for 2nd host
10-15-2009 03:38 PM
switch
ip routing
to make only L2
no ip routing
good luck
if helpful rate
10-15-2009 04:48 PM
Thank you!
08-29-2017 08:19 AM
i am trying to configure 2 vlan with different network
vlan10 - 192.168.10.1/24
vlan50 - 192.168.50.1/24
port assigned to vlan10 is fa0/1-4 and fa0/5-8 for vlan50
client ips are
192.168.10.11-14 /24 for vlan10 with gateway 192.168.10.1
192.168.50.11-14 /24 for vlan 50 with gateway 192.168.50.1
however they cant reach each other, i am trying Layer3 switching and i am did the ip routing as what you advise but did not work..
please advise if i did wrong.. thanks and advance.!!
01-10-2020 11:55 PM
Have you try with interface VLAN ?
(Config)#Int VLAn 10
#ip address 192.168.10.1 255.255.255.0
(Config)#Int VLAn 50
#ip address 192.168.50.1 255.255.255.0
Please try this and let me know if its working or not
05-21-2020 05:20 PM
10-15-2009 03:42 PM
example:
Int vlan 100
no shut
conf t
int gi 0/1
no shut
repeat for 2nd host
10-15-2009 04:51 PM
Thank you!
03-01-2022 07:56 AM - edited 03-01-2022 08:17 AM
I have c3560cx-12pd-s and i am not able to reach a host on the second vlan(20). I can ping to vlan 10, vlan 20, but the host in vlan 20 is unreachable for me. Can anybody advice me please? Is it necessary to use two switches or I am able to rout on this switch(c3560cx)?
