Fast busy when calling extensions in same CSS
Oct 15th, 2009
We are getting a busy signal when dialing from an IP phone to a FXS port. The extension numbers 80XX are in the same calling search space, does anyone have any ideas on what to research? We have changed the CSS classification between the FXS ports to see if that made a change...fast busy. Could it be the router causing the busy signal. TIA - Thomas NH
Chris Deren Fri, 10/16/2009 - 08:36
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
CSS on the GW has nothing to do with inboud calls, here is what to look for:
Is this MGCP or H323 controller FXS port? If MGCP make sure the DN is assigned to proper parition
If H323 make sure you have matching dial-peers on the GW pointing to the FXS ports.
Chris
Brav3h3art Fri, 10/16/2009 - 12:21
Hi Chris -
Its MGCP and all extension are in the same unique partition. I'll check the dial-peers on the router again. What I do not understand is, it's an intermittent busy on FXS ports? If I dial from an IP phone to an IP phone in the same DID range (partition)the phone rings OK, but if I dial a FXS port in the same DID range (partition) I get busy tone. I have done 10 Nortel to VoIP conversion this year and have never seen this problem ever. We are running CUCM 6.12 and have several sites out there with almost same setup, but do not have these types of problems. I wonder if it has anything to do with the OSPF? I am open for anything - Thanks Thomas NH
Brav3h3art Fri, 10/16/2009 - 13:16
Nick,
That issue is related to CLID on outbound calls, we are OK there. We are passing the External Phone Number Mask with no problems on the PRI T1s. This problem is within the partition itself and is a major problem. Mainly my project is in jeopardy from being cut over. Any other ideas...TIA-ThomasNH
Nicholas Matthews Fri, 10/16/2009 - 13:44
  • Red, 2250 points or more
debug mgcp packet
debug voip ccapi inout
debug vpm signal
on the fxs gateway.
"I call and get busy tone" can be literally a hundred things.
-nick
