6509 with vss supervisor
Oct 15th, 2009
dear all,
i'm planning to have 2 6509's with virtualization supervisors. if i use this kind of a supervisor is it possible for me to use FWSM and wireless lan controller modules in this chassis.
can anybody give some idea about this.
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Thu, 10/15/2009 - 23:59
Hello Srinidhi,
it is possible, but before setting up the VSS you need to upgrade each service module firmware to the correct version.
see following document for service modules in VSS
To be noted: in last mounths some colleagues have reported problems in doing this.
Also there is an Ask the expert event about VSS that can be helpful
Hope to help
