what's the meaning of Method in show ip int bri??
Answered Question
Oct 16th, 2009
hi all,
I wonder what's the meaning of Method in show ip int bri
Method : nvram, unset, manual...
what's the difference among them??
is anyone knows about this? or document?
Correct Answer by Giuseppe Larosa about 7 years 8 months ago
Hello Sanghee,
the method is a short way to tell how the ip address has been given to the interface:
nvram -> saved config
manual -> configured after last reload
unset -> simply not configured
there should also an option for when you set the ip address using the initial setup dialog on a device with an empty or skipped configuration.
see command reference
http://www.cisco.com/en/US/partner/docs/ios/ipaddr/command/reference/iad_ip.html#wp1027146
or
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_ip.html#wp1027146
Table 30 provides the following list
The Method field has the following possible values:
•RARP or SLARP-Reverse Address Resolution Protocol (RARP) or Serial Line Address Resolution Protocol (SLARP) request.
•BOOTP-Bootstrap protocol.
•TFTP-Configuration file obtained from the TFTP server.
•manual-Manually changed by CLI command.
•NVRAM-Configuration file in NVRAM.
•IPCP-ip address negotiated command.
•DHCP-ip address dhcp command.
•unassigned-No IP address.
•unset-Unset.
•other-Unknown.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 10/16/2009 - 00:12
  • Hall of Fame,
    Founding Member
Hello Sanghee,
or
•unset-Unset.
•other-Unknown.
Hope to help
Giuseppe
Sanghee Han Fri, 10/16/2009 - 00:24
Thanks for your help.
it's great help to me.
Thanks again :)
