Aironet 1200 Keeps Losing IP/Web Interface
Oct 16th, 2009
Hi guys,
I am new to using aironet. I first set the fast ethernet 0 to obtain IP address via DHCP (my broadband router) which it did. I still couldn't ping or open the web management browswer via the IP address allocated.
The IP address fell off the broadband router after about a minute. The other 3 devices connected are fine so it isn't the router.
I then allocated a static IP to the fast ethernet 0 on the aironet and directly connected to my laptop via crossover. laptop was 172.16.1.2 and aironet was .1 but they still couldn't ping eachother and the web management window wouldn't open.
I have no idea how I can connect to the AP to configure it via the web management interface. I need to use that as I want to capture screen shots for a lesson plan.
System image file is "flash:/c1200-k9w7-mx.122-13.JA1/c1200-k9w7-mx.122-13.JA1"
cisco AIR-AP1210 (PowerPC405GP) processor (revision A0) with 14326K/2048K bytes of memory.
any help much appreciated.
ap#sh ip int brie
Dot11Radio1 unassigned YES TFTP up up
FastEthernet0 172.16.1.1 YES manual up down
BVI1 10.0.0.1 YES manual up up
Virtual-Dot11Radio0 unassigned YES TFTP down down
weterry Fri, 10/16/2009 - 18:35
  • Silver, 250 points or more
interesting. I'm pretty sure you want your BVI to be the one with the IP address.
Fa0 and Dot11Radio0 should be in bridge-group1 by default, which would map to BVI1.
If you clear the config, it should pull dhcp by default off the bvi1 port....
