10-16-2009 04:18 AM - edited 03-15-2019 08:06 PM
Hi all,
My problem is the CME or the unity express is dropping the call coming from the wan.
For calls from the PSTN or from the local network the unity is answering correctly.
Anybody know what could be the problem?
I will appreciate any help.
10-16-2009 04:22 AM
Are you using G711 for wan calls to CUE ?
Otherwise, you need to configure transcoding on the hosting CME.
10-16-2009 04:47 AM
thanks,
but how this configuration should be done?
this is the dial-peer to unity
dial-peer voice 635555 voip
description To VoiceMail
destination-pattern 63555.
session protocol sipv2
session target ipv4:10.124.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
thanks
10-16-2009 04:49 AM
To begin with, can you ping 10.124.10.1 ?
Then, take "debug ccsip message" with "term mon".
10-16-2009 04:53 AM
yes, the ping responding.
The debug I will post later because this can be only done in the non-business hours.
10-16-2009 04:55 AM
Debug ccsip message can be done at any time, it is of no impact.
10-22-2009 11:05 AM
07-27-2011 05:16 AM
Did you have a solution to this problem. I am having a similar issue.
07-27-2011 05:47 AM
Start a new thread, post up your configuration.
Aaron
