DMP 4400
Oct 16th, 2009
I would like to know if the 4400 can control a television? Having the ability to change iputs, turn on/off from the user interface. So there is no need to go to the TV and make that adjustment. I see that there is an IR output that goes from the 4400 to the TV.
panayiotiscy Fri, 10/16/2009 - 05:04
In order to control your TV from the DMP you need an RS-232 port on your TV in order to receive the commands from the DMP.
In addition, you need to control this from the DMM.
DJL_PSB1231 Fri, 10/16/2009 - 05:10
The TV's that are in place have no RS232 input. Is there a converter that can be used? Also, the 4400 can't use one of the other outputs ie:HDMI, USB, IR to control the TV?
Charles Little Fri, 10/23/2009 - 10:24
  • Bronze, 100 points or more
No there is no converter you can use. In order to take advantage of this feature you must be using commercial or professional grade LCDs with RS232 Ports for the transfer of those hexidecial codes that control Display functions. The control of the LCDs is actually an application function of the DMM but the commands are transfered to the display through the DMP. NEC and Cisco LCDs are native but other makes and models can be prorammed if you know the hex codes for the display.
I hope this helps.
Cheers
C.O. Little
juwoods09 Mon, 11/02/2009 - 11:12
On similar terms, is there any other way to push/load content on to a DMP without using the network?
