Is it possible to have voice and data on separate vlans on spa 942 with firmware 6.1.5a
Oct 16th, 2009
Hi have tested the following and also different combinations but I cannot get the phone to work when I have 2 vlans
vlan 1=data
vlan2=voice
Phone configuration
Enable Vlans = no
CDP enable=yes
Enable PC Port VLAN Tagging:no
vlanid=1
on the switch I have the following
interface FastEthernet0/21
switchport multi vlan 1,2
switchport mode multi
switchport voice vlan 2
spanning-tree portfast
I can ping the pc attached to the phone on vlan 1 but cannot ping the phone which should be on vlan2.
I have tried all sorts of combinations of settings including setting the switch as a trunk but could not get the phone to work.
Can you pls indicate what I am doing wrong pls?
Chris Debono
marck_renton Mon, 10/19/2009 - 13:26
You can't ping the phone beacuase you have only one vlan on your phone. the correct configuration must be as follow in your phone:
Enable Vlans = yes
vlanid=2 (this is the vlan for the ip phone)
CDP enable=yes
pc port vlanid=1
I hope that it helps
Best regards.
