VSL-Portgroup, which int belongs to it?
Oct 16th, 2009
When trying to configure "mls qos trust dscp" on the Gig-interfaces on a Sup720-10G in virtual mode I get the following error message:
" HWIF-QOS: QoS configs are not allowed on VSL Portgroup."
As far as I know only the 10G-int can be part of the VSL. Can somebody explain this and tell if it is impossible to trust DSCP on these Gig-ports when using the 10G ints for VSL.
Svante Bolander Fri, 10/16/2009 - 09:44
But as I understand it it is only the TenG-interfaces that are part of the VSL-group. Why should the gigE be affected by the shortcomings of the VSL-interfaces.
Reza Sharifi Fri, 10/16/2009 - 10:12
  • Cisco Designated VIP,
    2017 LAN
Can you post your VSL config here?
What if you use 10Gig ports from a line card for your VSL link instead of the Sup ports?
mhaaksma Tue, 11/10/2009 - 12:58
Did you ever find out what it going on with this? I just ran into the same issue and I'm unable to find anymore information.
Thanks!
Mark
Svante Bolander Wed, 11/11/2009 - 06:32
No.
But as I understand, this is a shortcoming that tells you not to use any of the three Gig interfaces at all when running VSL on the 10G's. I have also found that using one of the Sup-10G int, together with one int on a 6708 LC, to form a etherchannel bundle to an access switch is impossible due to missmatch in QoS-capabilties.
mhaaksma Wed, 11/11/2009 - 07:30
Yeah, one of my coworkers suggested I look to see what ASIC(s) the gig ports were attached to... So it appears that ports 1-5 (gig and ten) are all on a single ASIC. So that explains it! Once you turn on VSL there really isn't anything you can do with the gig ports for QoS.
iyde Wed, 11/11/2009 - 13:23
  • Silver, 250 points or more
Hi.
To the best of my knowledge you cannot set separate QoS config for the 1gig ports of the Sup720-10G when you use the 10Gig ports for VSL. However, I do not as such have a link to underline my info - it's something I believe I heard from a colleague.
HTH, Ingolf
