Accessing HUM database
Oct 16th, 2009
Is it possible to access HUM database via odbc? I found a doc how to access RME, CM and DFM database but not HUM. If possible, is there any documentation I can refer to?
Joe Clarke Fri, 10/16/2009 - 07:40
No, currently the HUM database cannot be accessed directly. This is due to some performance issues. There is a plan to open this up in LMS 4.0 due out next year.
mohdnazmi Fri, 10/16/2009 - 07:56
I need to extract data out from HUM to produce report different from the given template using other reporting tools. What are the other option do I have to make this possible?
Joe Clarke Fri, 10/16/2009 - 08:59
Currently there are no other options. This is not yet possible.
sanja_vukovic Mon, 03/08/2010 - 05:57
I am interested how to access RME via ODBC. I am aware it is not documented, and it can change without notice.
Please can you send me a link to a doc you are reffering to.
thank you very much
