RV042 - VPN Gateway to Gateway connection
Oct 16th, 2009
I would like to know how to configure a VPN connection between two RV042.
One side is static IP (side A) and the other one is dynamic IP (side B).
I have tried the following:
side A:
Local Group - IP Only
Remote Group - Dynamic IP + Domain
side B:
Local Group - Dynamic IP + Domain
Remote Group - IP Only
Both of of routers have the same (latest .19) firmware.
If side B is static IP the VPN connection can be made.
Tks.
daviddun Mon, 10/19/2009 - 07:44
Good Morning,
You may need to call SBSC for support if you are still having problems.
1-866-606-1866
I would look at the setting being this
side A:
Remote Group - IP Only with IP by DYNDNS (2nd Column)
side B:
Have a great day :)
