after CM upgrade, Mesage Waiting Light will not be lit
Answered Question
Oct 16th, 2009
Whenever we do a CM upgrade, we will always have one phone that receives VM but no MWL. It is usually several days later when the user realizes it. It is always a different extension. What causes this and what can we do to prevent this problem?
Correct Answer by Rob Huffman about 7 years 5 months ago
Hi Mary,
Long time my friend! Hope all is well.
This is very common when doing any significant changes on CUCM (like an upgrade). The way we usually mitigate these type of issues is to run a MWI Re-sync after the changes are done (usually the last step).
In Unity Connection go to Telephony Integrations - Phone System - Click the Run Button for Synchronize All MWIs on This Phone System.
This is available in Unity versions as well :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 10/16/2009 - 09:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mary,
Hope this helps!
Rob
maryclegg Fri, 10/16/2009 - 09:59
Thanks, Rob. I knew you would know the answer. Hope all is well with you also.
maryclegg Fri, 10/16/2009 - 10:48
Rob, can I do that resync now during regular business hours while all the users are here or will it cause interruptions?
Rob Huffman Fri, 10/16/2009 - 12:13
  • Hall of Fame,
    Founding Member
Hi Mary,
Life is really great here :) I would run the MWI re-sync afterhours.
Cheers!
Rob
