ASA5505 Managment on Outside Interface
sjoyce
Is it possible to manage the ASA5505 via the outside interface. We are setting up a VPN Tunnel between to ASA5505s and the INSIDE interface on the remote ASA will be connecting to another network which we have not control of.
Thanks Mucho!!!
2 Accepted Solutions
JORGE RODRIGUEZ
Level 10
Level 10
If you are trying to manage firewall through ipsec tunnel you shoudl still have control of your inside interface and manage it through that interface..
management-access inside
and allow the host that needs to manage the firewall for telnet and http etc..
if the host is not part of that ipsec tunnel but needs to manage the firewall, then you can manage it through oustide interface by simply allowing that host in your http and telnet statements.
i.e
http outside
etc..
Jorge Rodriguez
Collin Clark
From the outside you can use SSH, VPN, or ASDM. Here's how to configure SSH.
PIX(config)#hostname PIXOne
PIXOne(config)#domain-name mydomain.com
PIXOne(config)#crypto key generate rsa
PIXOne(config)#ssh time-out 60
PIXOne(config)#ssh [your public IP] 255.255.255.255 outside
Hope that helps.
JORGE RODRIGUEZ
Level 10
Level 10
i.e
http outside
etc..
Jorge Rodriguez
Jorge, thanks for your reply. Sometimes the easy fixes appear as real problems.
Thanks Mucho!!!
Collin Clark
Hope that helps.
Collin, thanks for your reply. Sometimes the blinding obvious escapes one!
Thanks Mucho!!!
