Edison Ortiz Fri, 10/16/2009 - 09:41
Siva,
We need more information.
Hardware in question and the exact command being executed.
Can you copy and paste the output while trying to delete the file?
In some platforms, you may need to use the erase command instead of the delete command while removing objects from the file system
Edison
sivaprakasam81 Fri, 10/16/2009 - 09:50
The information follows,
Cisco 4948 Switch. Cisco IOS.
Switch#delete cat4500:vlan.dat
error% permission denied
Thank you,
Siva
sivaprakasam81 Fri, 10/16/2009 - 10:33
1. I see that the directory is available with Vlan info:
Switch#dir cat4000_flash:
Directory of cat4000_flash:/
1 -rw- 0 vlan.dat
524280 bytes total (524280 bytes free)
2. I use erase command and it is successful
Switch#erase cat4000_flash:
Erasing the cat4000_flash filesystem will remove all files! Continue? [confirm]y
[OK]
Erase of cat4000_flash: complete
3. It still has the vlan information. how can i delete those vlan info.
Switch#show vlan
VLAN Name Status Ports
1 default active Gi1/1, Gi1/2, Gi1/3, Gi1/4
Gi1/5, Gi1/6, Gi1/7, Gi1/8
Gi1/9, Gi1/10, Gi1/11, Gi1/12
Gi1/13, Gi1/14, Gi1/15, Gi1/16
Gi1/17, Gi1/18, Gi1/19, Gi1/20
Gi1/21, Gi1/22, Gi1/23, Gi1/24
Gi1/25, Gi1/26, Gi1/27, Gi1/28
Gi1/29, Gi1/30, Gi1/31, Gi1/32
Gi1/33, Gi1/34, Gi1/35, Gi1/36
Gi1/37, Gi1/38, Gi1/39, Gi1/40
Gi1/41, Gi1/42, Gi1/43, Gi1/44
Gi1/45, Gi1/46, Gi1/47, Gi1/48
2 Interconnect active
15 VLAN15 active
16 VLAN16 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
Thank you,
Siva
Giuseppe Larosa Fri, 10/16/2009 - 10:38
Hello Siva,
reload the switch now that the file is empty
>> 1 -rw- 0 vlan.dat
vlan.dat is read at startup
Hope to help
Giuseppe
sivaprakasam81 Fri, 10/16/2009 - 11:17
Thank you for your inputs. YOu are right. When I reload the Switch, it again comes with VLAN.dat information. It seems I am loading the Customised Cisco IOS. How can I load the fresh OS from my desktop to 4948 Switch using Console port. I can access Switch# prompt also rommon>. Please provide steps to load Cisco IOS via Console port. I do not have the Ethernet port connected with the computer to perform tftp.
Thank you,
Siva
Edison Ortiz Fri, 10/16/2009 - 12:49
If you are getting the Vlan information again, you must verify you aren't connected to other switches where this information is stored. You must understand, the default setting is VTP server where information from other switches will be copied to this switch.
If you want to have a clear vlan.dat file (you will always have one, btw) - you need to shut down all inter-switch links - perform the erase command as I instructed then reboot.
After a reboot, you will have a new vlan.dat and no vlan information after typing 'show vlan' other than the default vlans.
Edison.
